1993 Chevy Corsica Corsica jerks
SUNSKYJEN
  • 1993 CHEVROLET CORSICA
Shakes or Wobbles problem
1993 Chevy Corsica 6 cyl Four Wheel Drive Automatic
Why is my 1993 chevy corsica jerking when I accelerate to 30
Friday, August 28th, 2009 AT 8:17 PM
Oxygen sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, August 28th, 2009 AT 8:52 PM
