Serpentine Belt
VLROB69
  • 1994 CHEVROLET CORSICA
  • 6 CYL
  • 105,000 MILES
How do I replace my serpentine belt. The pulley on top has a motor mount does it have to be removed and if so does the motor need to be supported?
Saturday, November 29th, 2008 AT 8:06 PM
BMRFIXIT
  • 19,053 POSTS
Locate the tensioner and lift away from the belt
Be sure to draw how the belt is routed if there is no under hood sticker showing it
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_95.jpg
Read the guide below, its not vehicle specific, but it will help
https://www.2carpros.com/articles/replace-serpentine-belt
Saturday, November 29th, 2008 AT 8:12 PM
JCAPONE
  • 1996 CHEVROLET CORSICA
  • 4 CYL
  • FWD
  • 185,000 MILES
My serpentine belt keeps breaking, I found that the bottom pulley (with grooves) does not move. Is that the problem?
Monday, November 19th, 2018 AT 5:36 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi jcapone,
If the main pulley is not moving, the serpentine belt would not move. The main pulley must move when the engine is running.
I am confused by your question.
LISABARNETT
Engine Mechanical problem
1994 Chevy Corsica 4 cyl Front Wheel Drive Automatic
need to know the way to put it on
BLUELIGHTNIN6
  • 16,542 POSTS
Let me know if your engine size is different than 2.2L
2.2L Engines:
https://www.2carpros.com/forum/automotive_pictures/261618_0900c152800a7034_1.jpg
Thanks for using 2CarPros.com!
SAMPO2345
What is the length of the belt without ac compressed bearing fried so don't need ac was gonna put belt on and need to know length without ac
LITTLEONE42069
1994 Chevy Corsica 6 cyl Wheel Drive Type unknown Automatic 30000 miles
I need a printout that shows how to replace the belt on the engine
BMRFIXIT
  • 19,053 POSTS
Check the diagram below
locate the tensioner and pull away from the belt
pull belt
https://www.2carpros.com/forum/automotive_pictures/99387_corsica_1.jpg
HALLSHIVE91
  • 6 CYL
  • 150,000 MILES
I need a diagram for a v6 3100 serpentine drive belt
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_207.jpg
2CP-ARCHIVES
  • 4,540 POSTS
  • 18,400 MILES
How change serpentine belt on 2.2L 1996 corsica with 184,000 miles
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,687 POSTS
Here is a guide that will show you what you are in for when doing the job.
Here is a guide to show you how it is done on your car
https://www.2carpros.com/diagrams/chevrolet/corsica/1996
Cheers, Ken
LJFREELAND
  • 1990 CHEVROLET CORSICA
  • 4 CYL
  • FWD
  • 175,000 MILES
I started the car this morning and heard a strange clicking kind of noise. Thought a bird got caught in the belt or something. Then realized I had no power steering. Looked under the hood and the belt is so way loose, but not broken. How do I tell if its the belt or the tensioner. The belt is real loose. It's old but not frayed. Some cracks in it. Could it have stretched that far? How can I tell if it's a bad tensioner?
WRENCHTECH
  • 20,761 POSTS
If it's the correct belt, routed correctly and none of the pulleys are bad, then all it can be would be the tensioner.
KOLEC94
  • 18 POSTS
  • 3.1L
  • V6
  • 135,000 MILES
My drive belt is going bad, and I have been putting oil on it and it slipped off and now I cannot figure out how to release the tensioner on the belt.
HMAC300
  • 48,601 POSTS
Worse thing you can do is to put oil on a belt. Clean all the pulleys with choke cleaner or brake clean then replace the belt and tensioner. See picture arrow shows which way to move tensioner.
KOLEC94
  • 18 POSTS
How do I move the tensioner?
HMAC300
  • 48,601 POSTS
I already showed the direction in first reply with the picture move it in the way of the red arrow.
KOLEC94
  • 18 POSTS
Ok so I have to unbolt the tensioner?
HMAC300
  • 48,601 POSTS
Only if you replace it which you should due to age and replacing belt as well.
