1993 Chevy Corsica Starting Problems
TYLAINES
  • 1993 CHEVROLET CORSICA
1993 Chevy Corsica 6 cyl Automatic
Hello I have a 1993 Chevy Corsica I was driving it one day and it made a click sound and then stalled. It will not start or nothing else. I check the fuel pump and it is running I put a new fuel filter on it and the coil is firing just fine. Can you please help me figure out what is wrong with my car.
Thank You
Sunday, January 11th, 2009 AT 1:47 PM
  • 109,885 POSTS
Hi:
If you have spark and fuel, it should run unless:
1) fuel pressure is too low
2) weak spark
3) broken timing belt
4) low compression.
I suggest checking the fuel pressure and make sure you are getting a good hot blue spark.
Let me know what you find.
Tuesday, January 27th, 2009 AT 6:58 PM
