1989 Chevy Corsica radiator fan
1989 CHEVROLET CORSICA
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
EAGLEBOB
I recently installed a used but good radiator and my car is still overheating. I noticed that the fan will not come on and I can't figure out why. I need to know where the temperature sensor is located. I also wonder if maybe it can be an electrical problem. If you can answer this question, it will be greatly appreciated.
Jan 1, 2008 at 4:03 AM
TDW466
It should be up near the thermostat housing. If you disconnect it the fan should turn on.Then you know its the sensor. If it doesnt then you should check the fan motor. Get a couple of jumpers and put power to it from the battery.hope this helps.
Jan 22, 2008 at 11:04 AM
