2006 Chevy Cobalt a/c clutch
81,000 MILES • 4 CYL • FWD • MANUAL
WHIT05
The clutch on my A/C pump is not engaging. I have checked the fuses and switched the relays to ensure they are not the issue. It was working fine when I parked it one day, blowing cold air and engaging and disengaging just like it is supposed to. Then the next day, nothing. I am thinking it is definitely something electrical and not caused by a lack of freon in the system. What could be the possible causes?
Jul 5, 2009 at 5:26 AM
  • 110,248 POSTS
Have you checked to see if you are getting power to the compressor? It could be either electrical, or you may have lost freon from a leak. Check to see if there is power to the unit.
Jul 9, 2009 at 2:43 PM
