Could be a lot of things, but sounds like a clogged CAT. It will cause excessive backpressure, in extreme cases it will build up enough pressure to cause exhaust valve to not close.
Either remove CAT and inspect or perform a CAT backpressure test.
SPONSORED LINKS
Friday, October 8th, 2010 AT 9:24 AM
