1992 Chevy Cheyenne pedal
1992 CHEVROLET CHEYENNE
DIKNMIST
Brakes problem
1992 Chevy Cheyenne V8 Four Wheel Drive Automatic
i changed the brake lines and tried to bleed brakes but cannot get any pressure on the pedal.
Nov 1, 2008 at 1:01 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
You can bleed it... Bench bleed the master by getting brass plugs and screw them into the two ports, then pump the master until you cant move the piston any more. Attach the lines, Have an aide press and hold the pedal crack the lines and retighten, repeat this till all air is removed at the lines, Don't let the master run dry, bleed rear cylinders by opening the bleeders and wait until the fluid dripps out. Close bleeders. Make sure the rears are properly adjusted, then test the pedal hieght. If you did the front lines do the same there, you still have air in the system...
Nov 1, 2008 at 1:21 PM
