1993 Chevy Cheyenne break line (rear)
1993 CHEVROLET CHEYENNE
TINA PANGBORN
Brakes problem
1993 Chevy Cheyenne
I avoided an accident and in the process my break line going to the rear breaks sprang a good size leak. I need to know if I can repair myself. Thanks for any feedback.
Aug 28, 2010 at 9:49 AM
HMAC300
  • 48,601 POSTS
you should be able to repair it yourself. If you have to shorten it then you will need a tool to put a double flare on it as brake lines use double not single flares. Also DO NOt under any circumstances use a compression fitting anywhere to connect any lines. Use a connecter otherwise you will cause the brake to hang up and wear very quickly.
Aug 29, 2010 at 8:12 PM
