I'm having what seems to be a fuel issue with my 92 Chevy 1500, 4.3L V6. It will start and run until warm, but past that it cuts out during driving or if left at idle. I have already replaced the fuel pump(can hear it running), fuel filter, and the fuel pressure regulator. Once the truck quits, it will restart if I use ether or leave it alone for 30min-1hr. It runs fine but will eventually cuts out again. The truck only seems to cut out near idle speed. There are no check engine lights on at any time.
SPONSORED LINKS
Tuesday, October 13th, 2009 AT 12:29 PM
