1997 Chevy Cheyenne almost stalls out wen im at a red light
1997 CHEVROLET CHEYENNE
146,521 MILES • 6 CYL • 2WD • MANUAL
JOEGETRIGHT
I recently installd new MFI injectors in my truck. It ran well for a day. now it almost stalls out when i come to a complete stop. other than that it runs great.
I upgraded the injectors because 1 of the old injectors whent out, and ive had them cleand out before and i was told that if didnt upgrade to to the newer ones they would peridically go bad.
I would appreciate anyhelp help this
thanks
Aug 28, 2010 at 5:37 AM
HMAC300
  • 48,601 POSTS
make sure you don't have any vacuum leaks, spray choke cleaner around the manifold wher eit comes together. Then use the choke cleaner to clean the throttle plate on both sides and if you haven't changed the fuel filter recently change that. If it continues, check the fuel pressure.....
Aug 29, 2010 at 1:15 PM
