1988 Chevy Celebrity Hard Downshift
CLARK W GRIZWALD
I have a 1988 Chevy Celebrity with a 2.8lL engine with 96,000 miles and an automatic trans with overdrive.
It up-shifts fine, but when slowing down it hits hard into first gear at around ten miles per hr.
And when I shift into reverse it also hits hard into reverse. What could be the cause?
The fluid level is correct but never has been changed.
Feb 14, 2007 at 11:16 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_images_2.jpg
I would start off with a transmission filter and fluid. IT should been done 3 times by now.
Feb 14, 2007 at 12:24 PM
Suggested Repair
Service the automatic transmission by replacing the fluid and filter. The fluid has never been changed and is overdue for multiple services.
Conversation Summary
The owner of a 1988 Chevrolet Celebrity with a 2.8L engine and automatic overdrive transmission reports normal upshifts, but a hard engagement into first around 10 mph when slowing and a hard engagement into reverse. Fluid level is correct, but the fluid has never been changed. The expert recommends starting with a transmission fluid and filter service, noting it should have been done several times by now.
