1989 Chevy Celebrity
144,120 MILES • 4 CYL • FWD • AUTOMATIC
TIGERTANK72
I have changed the fuel pump, and the sparkplugs and wires, and every little thing that i could think of. The car runs great but every now and then something locks up and the car stalls. It'll start back up, but once i shift it into gear it stalls again and won't go anywhere. I believe it's the torque converter in the transmissoin, but I'm not sure. If so, what do i have to do to replace it?
Mar 9, 2010 at 1:03 AM
HMAC300
  • 48,601 POSTS
first try choke cleaner an dclean the throttle plate on both sides as well as the hole for idle air control. then haveyour transmissino checked by a pro if it still does it. replacing a converter only at your mileage and adding new fluid will certainly eat the clutches up in yourtrans misssion. try that.........
Mar 19, 2010 at 5:45 AM
