On 1996 Cavalier 2.2L engine base coupe with 135,000 miles:
the car overheats at idle, the radiator fan does not come on. The fan works if the AC or heater is turned on. What might be the problem(s)?
Wednesday, April 4th, 2007 AT 6:52 AM
TODDABE
MEMBER
Hi. I am not anything more than a "my own garage" mechanic but I have a 95 cavy that did the same kinda thing, except the radiator fan didn't work at all, and I replaced the thermostat and the motor for the radiator fan and that fixed my problem. I would definately take a look at your thermostat. Good Luck
