2002 Chevrolet Cavalier Steering Leak
LESLIECLA
I have a 2002 Cavalier with 60,000 miles on it. The power steering feels like it's working fine (not hard to turn, etc.) but there has been a wheezing sound coming from the steering column when I turn. I took it to one mechanic who indicated a power steering fluid leak that required replacing the rack, hose, and belt. A second mechanic (whom I have used before) diagnosed a leak as well, but recommended replacing the pump and did not say anything about the rack. Not knowing enough about this - if the fluid is leaking onto the belt (as both mechanics said), will replacing the pump solve that problem, or will the rack eventually have to be replaced anyway? Should I mention the rack to the second mechanic, or would he have definitely caught that problem if it was actually a problem?
Thanks!
Apr 2, 2007 at 4:34 AM
BOOTDOG
  • 665 POSTS
first of all you need to find out exactly where the leak is coming from. if it's the pump, replace it, clean up where the power steering fluid has leaked onto and check to make sure it's not leaking anywhere else.
Apr 2, 2007 at 10:27 AM
Suggested Repair
Locate the exact source of the power steering fluid leak before replacing parts. If the pump is leaking, replace it, clean off fluid that reached the belt or nearby parts, and confirm there are no other leaks.
Conversation Summary
A 2002 Chevrolet Cavalier with 60,000 miles has a wheezing sound from the steering column while turning, although steering effort feels normal. Two mechanics found a fluid leak onto the belt but disagreed: one recommended replacing the rack, hose, and belt, while the other recommended replacing the pump. The expert advised identifying the exact leak source first, replacing the pump only if it is leaking, cleaning the leaked fluid, and checking for leaks elsewhere.
