Overheating
H34HIYA
  • CHEVROLET CAVALIER
I have a 96 cavilier with a 2.2 engine and 130,000 miles. It overheated and I cant find out why. I changed the thermostat to no avail. The water hoses feel full of water when running but the seems to be little or no circulation.
Monday, July 16th, 2007 AT 12:58 PM
E40WATER12
  • 522 POSTS
Have you checked to see if youre cooling fan is kicking on, When its about to climb in temperature. Could have a bad fan relay switch. U could try and run a jumper wire from the battery to the power wire on the fan see if it kicks on. If it does, Then youre fan relay is no good. I would also check youre fan Fuse as well. Could be blown if youre fan doesnt kick on.
Tuesday, July 17th, 2007 AT 4:31 AM
