1999 Chevy Cavalier Overheating
BECKYBENNETT
I own a 1999 chevy cavalier 2 door coup. 2.2 ltr. since I bought this car brand new it had a tranny problem that required replacement in the first 6 months I had it and at about 70,000 miles i had to replace the alternator. Other then that this car has been a peach.it now has 94,000 miles. I took this vehical into a quick lube that I had taken it to before just for an oil change on this last saturday. They told me the regular speel, I needed to flush the radiator and the tranny and that the air filter was dirty. I told them not to do anything that day but change the oil. They did so and i drove it home about 4 blocks. I had planned a trip the next day to portland international raceway because I had won tickets to participate in hotlaps. I never made it. 20 miles from town the car started to really get a high temp reading and the radiator light came on. I pulled it over immediatly and got some coolant and water to add to the radiator thinking it was a little low because of the heat. It was empty. Bone dry. They had drained all of the coolant and never replaced it. With out my permission. Now the car is over heating and I cannot figure it out. I have water flow and i replaced the thermostat, to no avail. what do you suggest???
Sep 11, 2007 at 7:53 AM
  • 75,988 POSTS
[quote:eb83994de7="beckybennett"]I own a 1999 chevy cavalier 2 door coup. 2.2 ltr. since I bought this car brand new it had a tranny problem that required replacement in the first 6 months I had it and at about 70,000 miles i had to replace the alternator. Other then that this car has been a peach.it now has 94,000 miles. I took this vehical into a quick lube that I had taken it to before just for an oil change on this last saturday. They told me the regular speel, I needed to flush the radiator and the tranny and that the air filter was dirty. I told them not to do anything that day but change the oil. They did so and i drove it home about 4 blocks. I had planned a trip the next day to portland international raceway because I had won tickets to participate in hotlaps. I never made it. 20 miles from town the car started to really get a high temp reading and the radiator light came on. I pulled it over immediatly and got some coolant and water to add to the radiator thinking it was a little low because of the heat. It was empty. Bone dry. They had drained all of the coolant and never replaced it. With out my permission. Now the car is over heating and I cannot figure it out. I have water flow and i replaced the thermostat, to no avail. what do you suggest???[/quote:eb83994de7]
I'll say you have an air lock that needs to be bleed out. If it continues come back and we'll take up a notch.
Sep 11, 2007 at 8:07 AM
BECKYBENNETT
[quote:256dfcdb99="rasmataz"][quote:256dfcdb99="beckybennett"]I own a 1999 chevy cavalier 2 door coup. 2.2 ltr. since I bought this car brand new it had a tranny problem that required replacement in the first 6 months I had it and at about 70,000 miles i had to replace the alternator. Other then that this car has been a peach.it now has 94,000 miles. I took this vehical into a quick lube that I had taken it to before just for an oil change on this last saturday. They told me the regular speel, I needed to flush the radiator and the tranny and that the air filter was dirty. I told them not to do anything that day but change the oil. They did so and i drove it home about 4 blocks. I had planned a trip the next day to portland international raceway because I had won tickets to participate in hotlaps. I never made it. 20 miles from town the car started to really get a high temp reading and the radiator light came on. I pulled it over immediatly and got some coolant and water to add to the radiator thinking it was a little low because of the heat. It was empty. Bone dry. They had drained all of the coolant and never replaced it. With out my permission. Now the car is over heating and I cannot figure it out. I have water flow and i replaced the thermostat, to no avail. what do you suggest???[/quote:256dfcdb99]
I'll say you have an air lock that needs to be bleed out. If it continues come back and we'll take up a notch.[/quote:256dfcdb99]
thank :D :D you so much you were totally right. i did manage to shear off the bleeder screw, but we got it out and replaced it and the car runs like it did when it was new. thank you so much!!
Sep 16, 2007 at 3:45 PM
  • 75,988 POSTS
thank you so much you were totally right. i did manage to shear off the bleeder screw, but we got it out and replaced it and the car runs like it did when it was new. thank you so much!! I LOVE HAPPY CAMPERS!!!!!!!!!! I feel good
https://images.2carpros.com/forum/automotive_pictures/12900_muah1_7.gif
Good Luck! and Adios!
Sep 16, 2007 at 6:20 PM
Suggested Repair
Bleed trapped air from the cooling system after the coolant was drained and refilled. If the bleeder screw is damaged or sheared, remove and replace it, then confirm the engine no longer overheats.
Conversation Summary
A 1999 Chevrolet Cavalier 2.2L overheated after an oil-change shop allegedly drained the coolant and did not refill it. The owner refilled the system and replaced the thermostat, but overheating continued despite coolant flow. The expert diagnosed an air lock that needed bleeding. The owner bled the system, replaced a sheared bleeder screw, and reported the car then ran normally.
