CHRISSYLEW
i own a 1998 chevy cavalier z24 2 door 2.4 liter and it keeps leaking antifreeze. we fixed the problem after 5 attempts but now my fan doesnt kick on when its suppose to, or at all for that matter. i lost my drivers manual and i dont know where the fuses for the fan are so i dont know if that is the problem.... will i need to get a new fan or what?
Jun 21, 2007 at 7:45 AM
E40WATER12
  • 522 POSTS
If you look in youre engine compartment, On youre drivers side of the car, U will see a black color plastic panel, It contains fuses and relays, I would check out youre fan relay fuse, Could need replacing, Also Also u might want to use a piece of speaker wire, Run a jumper wire from the positive terminal to youre cars cooling fan, See if it turns on, If not youre cooling fan is no good, Also if youre fan turns on, Then youre fan relay switch is not good.
Good Luck.
Jun 21, 2007 at 8:14 AM
