1995 Chevy Cavalier Coolant Light
ARANEL
My 1995 cavalier has about 117000 miles, and the coolant light has been on for about two weeks. The coolant is green in color, and the light only comes on when I accelerate or make a sharp left. Then just this week, it refused to start when the weather was very hot or humid. Any thoughts would really help me out.
Jun 5, 2007 at 11:41 AM
E40WATER12
  • 522 POSTS
Well for the coolant light issue, Could have a plugged coolant switch, Or lower coolant level that needs to be filled up, Also has youre cars battery been tested?. Make sure its fully charged, How long has it been since you have had a tune up? Could need a new fuel filter, May need a fuel pressure test done.
Good Luck.
Jun 5, 2007 at 9:13 PM
Suggested Repair
Check and top off the coolant and inspect the coolant level switch for plugging. Test and fully charge the battery. For the hot or humid no-start, consider a tune-up, replace the fuel filter if due, and perform a fuel pressure test.
Conversation Summary
The owner of a 1995 Chevrolet Cavalier with about 117,000 miles reports a coolant light that has been on for two weeks, especially during acceleration or a sharp left turn, plus recent no-starts in very hot or humid weather. The coolant is green. The expert suggests a plugged coolant switch or low coolant, a battery test and charge, a tune-up, a fuel filter, and a fuel pressure test.
