1999 Chevrolet Cavalier Brake Lights Out
RYANDAIM
I have 99 cavalier with a 2.2 engine. My 2 side brake lights do not work, but my third one does. I have checked the sockets and they are fine. I do not have any voltage at either socket when I press on the brakes. I removed the socket to test the pins and get the same results. The turn signal works fine. I am thinking the turn switch in the column. Is there something I can check or replace?
Mar 6, 2007 at 11:13 AM
MIKE H R
  • 3,094 POSTS
i would vheck the fuses, sometimes the third brake light is on a diferent fuse.
Mar 6, 2007 at 12:21 PM
RYANDAIM
Fuses are good
Mar 6, 2007 at 6:22 PM
RYANDAIM
[quote:713c8d9ad3="M_J_RITZEL"]i would vheck the fuses, sometimes the third brake light is on a diferent fuse.[/quote:713c8d9ad3]
fuses are good
Mar 6, 2007 at 6:24 PM
  • 75,988 POSTS
Try testing the brake switch at the pedal it has to go thru there in order to make it back there.
Mar 6, 2007 at 6:38 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:36ad5a2022="rasmataz"]Try testing the brake switch at the pedal it has to go thru there in order to make it back there.[/quote:36ad5a2022]
Brake light switch might be the problem. i just had to change mine.
Mar 9, 2007 at 11:51 AM
Suggested Repair
Fuses were already confirmed good. Test the brake light switch at the brake pedal and replace it if it does not supply power to the side brake lights when the pedal is pressed.
Conversation Summary
A 1999 Chevrolet Cavalier with a 2.2 engine has inoperative side brake lights while the center brake light and turn signals work. There is no voltage at either side socket with the pedal pressed, and the sockets and fuses check out. An expert advised testing the brake switch at the pedal, and another owner reported that replacing that switch fixed the same problem.
