2002 Chevy Cavalier No Brake Lights
THOMASRL2
I have a 2002 Chevy Cavalier, almost 100,000 miles, automatic, 2.2 engine. A month or so ago I was driving and went to make a right and the turn single started blinking really fast. So I went and got a new bulb for the back turn single which doubles as a brake light. While changing the bulb, I see that half of the bulbs on the top break light that goes across the top of the trunk and burnt out, some even broken. I change all these bulbs, but still have no brake lights or turn single on the right. The brake light and left turn single worked fine until yesterday. I had a friend of mine check the bulbs, all were still good but didn't work. He said he checked all the fuses and that they were fine too. So I don't know what the problem could be and don't want to get overcharged for something that could be a simple task. :mrgreen:
Jul 29, 2007 at 3:02 AM
  • 75,988 POSTS
[quote:82da2e2b6c="thomasrl2"]I have a 2002 Chevy Cavalier, almost 100,000 miles, automatic, 2.2 engine. A month or so ago I was driving and went to make a right and the turn single started blinking really fast. So I went and got a new bulb for the back turn single which doubles as a brake light. While changing the bulb, I see that half of the bulbs on the top break light that goes across the top of the trunk and burnt out, some even broken. I change all these bulbs, but still have no brake lights or turn single on the right. The brake light and left turn single worked fine until yesterday. I had a friend of mine check the bulbs, all were still good but didn't work. He said he checked all the fuses and that they were fine too. So I don't know what the problem could be and don't want to get overcharged for something that could be a simple task. :mrgreen:[/quote:82da2e2b6c]
If it has power to the bulb socket and not turning On -you have a ground problem.
Jul 29, 2007 at 3:32 AM
Suggested Repair
If the bulb sockets have power but the lights do not come on, check for a ground problem.
Conversation Summary
The owner of a 2002 Chevrolet Cavalier reported a fast-blinking right turn signal, then no right brake or turn light after replacing bulbs, including several burned or broken high-mount brake-light bulbs. The left brake and turn lights later failed as well. Bulbs and fuses were checked and found good. The expert said that power at the socket without the light turning on indicates a ground problem.
