2003 Chevy Cavalier Taillight Out
CHES08
2003 Chevy cav
64.000 miles
Auto
My back right taillight won't work. I keep replacing the bulb but it won't work. The front one blinks real fast as if the back is burnt out. I know this part was recalled on my car a couple of years ago and it was fixed for free under warranty. byt when I call chevy they tell me that it's my responsibility since my car isn't under warranty anymore.
Is there a way to fix this at home? I think it has to be some type of wire issue
Aug 21, 2007 at 6:52 AM
MIKE H R
  • 3,094 POSTS
with the front one blinking fast, to me it sounds like the socket could be correded or a bad ground or a bad bulb. remove the socket and clean it out. replace with a new bulb. Just a little dirt will make it for a bad connection. check to see if it has a good ground.
Aug 21, 2007 at 8:46 AM
SERVICE WRITER
  • 9,123 POSTS
Incentives by manufacurerer to buy anothe car :evil:
Follow Mike's advice, in the event it is stil a problem, I would lean towards a socket based on how many I have come across.
Aug 22, 2007 at 12:34 PM
Suggested Repair
Remove and clean the rear right taillight socket, install a new bulb, and confirm a good ground. If the light still fails, replace the socket.
Conversation Summary
A 2003 Chevy Cavalier owner reports the rear right taillight stays out despite bulb replacements, while the front blinks rapidly as if the rear bulb is burned out. A prior recall repair is no longer covered. Advice is to clean the socket, fit a new bulb, and check the ground, then replace the socket if the problem remains.
