1999 Chevy Cavalier Stalls When Slowing
C4RIDDIM
im not a mechanic first of all lol but let me try and explain what i gathered overtime about my car problem. my brother has been doing mos of the mechanical work on this car and the check engine light is on all the time. he bought a diagnostic tool which told him after running for awhile that there is a fault with the MAP senson however it only showed up that once he cheked the voltages and the pressure and thy seemed to be consistent with what the book says it should be. however i want to know if despite this the sensor cud still b the problem. My symptoms are : when i slow down sometime like to turn corners it cuts off and if im reving it up in park it goes up so far and then like it makes a sound like it lost some pressure. Plz help i have changed sprak plug and wires, control module, the computer, fuel pump plus i have carried it to a couple mechancis who all gave different and even put it on diagnostics and still none that helped. when the car has cut off by itself i usually have to hold the gas pedal to the floor and try a few times b4 i can try it again. can some1 please give me an idea of my problem. I live in the bahamas so no dealership or anything here and very limited "good mechanics"
Jul 5, 2007 at 9:06 AM
E40WATER12
  • 522 POSTS
When the engine light is on, Have you scanned the trouble code?. And has the part been replaced?. Also does the engine light still come on?. Might need to use some carb cleaner on you IAC sensor on youre throttle body. Could be carboned up.
Jul 5, 2007 at 8:16 PM
C4RIDDIM
well like i said i carried to a repair shop twice and they had the scanner on it for awhile. my check engine light is always on. however after havin it on my brothers scanner for a long while a MAP sensor trouble code came up. im jus tryin 2 figure out wa cud b the problem because i was on another forum that told me usually map sensors don t go in these kinda vehicles n it was somethin else mayb causin the code. I havent tried the carbon spray yet what does the IAC sensor stand for?
Jul 6, 2007 at 2:48 AM
Suggested Repair
Scan and confirm the stored trouble code, then clean the IAC (idle air control) sensor on the throttle body with carburetor cleaner to remove carbon buildup that can cause stalling.
Conversation Summary
The owner of a 1999 Chevrolet Cavalier 2.2 reports a constant check engine light, a MAP sensor code that appeared once, and stalling when slowing for turns or after revving. Spark plugs, wires, a control module, the computer, and the fuel pump were replaced without resolving it. The expert asked whether the code was scanned and the related part replaced, and suggested cleaning a possibly carboned IAC sensor on the throttle body.
