Hi Michelle
could be coil pack sounds like you have covered the basics. But first let's find out which cylinder has the prob.
Remove one plug wire at a time with engine running from the coil pack. Engine should idle lower each time a wire is removed from coil pack the one that makes no diff plugged to coil or not. This will be the prob cyl find this out and write back and we will help you determine what is wrong with that cyl. Thanks billymac
SPONSORED LINKS
Friday, October 22nd, 2010 AT 7:00 PM
