1999 Chevy Cavalier ets light and service engine soon light
AFCUSHMAN
  • 1999 CHEVROLET CAVALIER
Engine Mechanical problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
My ETS light and Service Engine Soon light came on. Shortly after I had parked my car, now it won't start. Actually, if I hold the gas pedal in it will start, but as soon as I release the gas pedal it dies. I'm going to get some injector cleaner and try that. I was wondering if you have experienced this problem before.
Tuesday, December 23rd, 2008 AT 9:07 AM
2CARPRO JACK
  • 11,533 POSTS
Having the PCM scanned will most likely lead to the source of the lights and the reason it wont idle. It could be any number of sensors, but if the light is on, the PCM should have stored a code that will lead us in the right direction for a fix. Have it scanned and get back to me with the code/codes
Tuesday, December 23rd, 2008 AT 9:13 AM
AFCUSHMAN
  • 6 POSTS
I bought a OBD II pocket scan and received two codes.
THe first code is P0507 and the second is the same code just with a double P meaning it is a pending problem.
Saturday, December 27th, 2008 AT 3:01 PM
2CARPRO JACK
  • 11,533 POSTS
That code is for the IAC (Idle Air Control) motor circuit. First check to be sure there are no vacuum leaks. If none, then the IAC motor will most likely need to be replaced
Saturday, December 27th, 2008 AT 3:19 PM
