1999 Chevy Cavalier Idle Vibration
DAVYBOY
there are a few things wrong and i'm wondering if it is worth trying to save this car. first off when it idols, the entire engine block vibrates about 2 or 3 inches forward and back. second from what appears to be the connector for spark plug 4 (4 cylinders) there is a slight crack in the metal and it is continually making a click click click sound and occasionally i can see a blue spark arching from it to a small bolt between the connectors for plug 3 and 4. i was told a while ago that the spark plug head for cylindar 1 was cracked and that coolent was leaking into it but i do not know how credible that is, as my family has had many a dispute with the mechanics that said that. it allready has 215,000 kilometers on it and i don't know if it is worth trying to save this engine, or if in the long run a rebuilt or new engine would be better.
could someone please give me some non biased advice.
yours truely
~david
May 28, 2007 at 10:19 AM
E40WATER12
  • 522 POSTS
Just to let you know all 2.2L and 2.4 cavalier engines shake like that, Its the way they are designed, Also you motor mounts could be wornout, If u can see a blue spark from the spark plug hole, You got to make a choice what u want to do, A cavalier 215,000 kilometers, I still not to bad for km's, But if the car has been abused with over due oil changes, It could be better off doing a complete rebuild on the motor, It would save u a big head ache, Down the road, If the oil has been maintianed, Just get a new remanifactured cyl head, Hd Gasket kit, Then youre set, Cavaliers are great cars, Ive own 3 already,
May 29, 2007 at 9:43 PM
DAVYBOY
Thanx for the advice, i am getting the motor mounts tightened/replaced, and replaicing some of the wiring, as for the remanifactured cyl head, and Hd Gasket kit do you have an aproximate price???
May 30, 2007 at 10:40 AM
E40WATER12
  • 522 POSTS
For a ball park figure, Its what I paided before, to do a H/G job, It was $350 for Remanifactured cyl HD, Plus HD gasket $15-$30 dollars, Head bolt kit $35 / then I did the HD gasket job my self, I saved my self $850, Youre looking around $1200, For complete job, for a shop to do it. Could be cheaper,
Jun 4, 2007 at 8:28 PM
Suggested Repair
Idle shake is common on 2.2L and 2.4L Cavaliers, but worn motor mounts should still be checked and replaced if loose. Repair the cracked, arcing spark plug wire or boot at cylinder 4. If oil changes were neglected, a full engine rebuild is the safer long-term choice; if oil was maintained, a remanufactured cylinder head with a head gasket and head-bolt kit is reasonable. Ballpark costs cited were about $350 for the head, $15–$30 for the gasket, $35 for bolts, and about $1,200 for a shop to do the job.
Conversation Summary
The owner of a 1999 Chevrolet Cavalier with about 215,000 km reported strong forward-and-back engine vibration at idle, a crack and clicking near the cylinder 4 spark plug connector with a blue spark arcing to a nearby bolt, and an unverified earlier claim of a cracked cylinder 1 plug area leaking coolant. They asked whether the engine was worth saving versus a rebuild or replacement. The expert said this engine family shakes by design but worn mounts can worsen it, and advised choosing between a full rebuild if maintenance was poor or a remanufactured cylinder head and head gasket if oil changes were kept up. Approximate parts and shop costs were given. The owner planned to address the mounts and some wiring and asked about head-job pricing.
