1986 Chevy Cavalier High Idle
GENXSIS
I have a 1986 Chevy Cavalier, and just recently, I accidently left my interior dome light on after coming home from work and it ran the battery down. After putting an overnight charger on it for the night, I got it charged back up, and immediately noticed that upon starting it, the engine was racing. When I drive now, it wants to faster than I want it to down the driveway and I have to apply the brakes harder to stop at stop signs. I put the car in neutral when I'm coming to a stop now in order to save the brakes from wear and tear. When I do this, the car revs up and races the engine, which is just wasting gas.
The idle is very high when I first start the car, and when the car is in motion. But when I come to a stop and driving awhile, the engine slows back down to a normal idle. But when I start driving again, it speeds back up, and the car wants to go faster than I want it to. I actually had this problem once a few years ago too. At that time, I noticed something REALLY strange! If I stopped on a hill with the car shifted in neutral, the car's idle would eventually slow down to normal. Then if I took my foot off the brake and allowed the car to start coasting forward, the idle would suddenly become fast again. The same thing happened if I had the car shifted to "drive" when I did this, causing the car to lurch forward and start accelerating.
After several months of putting up with this problem, the problem went away all by itself. Now it seems to have returned. I hope to discover what the problem is caused by so maybe I can make it go away sooner.
Oct 9, 2006 at 9:26 AM
PEGSUE53
My Lumina does the same thing when the engine gets warm. The engine races, and if I take my foot off the gas pedal it will take off by itself. If I shut the car off it will run fine for a few mins. It does not do it all the time, it has a mind of its own. If you find out what causes it will you please let me know. peglines@hotmail.com. I have replaced the throttle control switch, the idle control switch. I have been told it could be the computer. I think if it was that it would do it do it all the time.
Oct 13, 2006 at 3:29 AM
MERCCRUISER
  • 16 POSTS
TRY ADUJSTING THE IDLE SPEED
Oct 13, 2006 at 1:33 PM
BURRBRIAN
  • 158 POSTS
Just a thought but maybe have the high idle solenoid checked? It's what normally makes it idle high when you first start up cold then lets the idle come back down after the car reachs operating temp.
Might go by a different handle on your car but a good mech. will know what you are talking about.
Oct 17, 2006 at 8:09 AM
Suggested Repair
Have the high idle solenoid (or the equivalent idle-control device on this car) checked, and try adjusting the idle speed.
Conversation Summary
A 1986 Chevy Cavalier began racing and holding a high idle after the battery was drained by a dome light and then recharged. The idle is high when first started and while driving, then drops to normal after sitting at a stop, and the same intermittent problem had appeared and disappeared years earlier. Another owner reported a similar warm-engine surge on a Lumina after replacing throttle and idle controls. Suggestions were to adjust the idle speed and have the high idle solenoid checked, since it normally raises cold idle and should release it at operating temperature.
