1996 Chevy Cavalier Coolant Loss
BAUERJ64
My daughter has a 96 Chevy Cavalier with a 2.2 liter, auto trans with about 180,000 miles on it. The problem we are having is that the coolant level keeps going down, and there are NO visible leaks, no coolant in the oil, no nothing. Been thinking on a headgasket leaking into the combustion chamber, but then wouldnt there be coolant in the oil? On a 50 mile trip it will go down 1-2 quarts. Cracked head another possibility? Any thoughts would be greatly appreciated. Thank you!
Jul 30, 2007 at 12:58 AM
BOOTDOG
  • 665 POSTS
look for white smoke coming out of the tail pipe. this is a good indicator coolant is getting into the combustion chamber. if so you're looking at a head gasket or cracked head.
Jul 30, 2007 at 1:37 AM
MIKE H R
  • 3,094 POSTS
Have the system pressure checked, to see if its internal or external leaks
Jul 30, 2007 at 1:50 AM
Suggested Repair
Look for white smoke from the tailpipe, which can indicate coolant entering the combustion chamber from a head gasket or cracked head. Pressure-test the cooling system to determine whether the leak is internal or external.
Conversation Summary
A 1996 Chevrolet Cavalier 2.2 with about 180,000 miles loses 1-2 quarts of coolant on a 50-mile trip with no visible external leak and no coolant in the oil. Advice is to check for white exhaust smoke as a sign of coolant burning in the combustion chamber and to pressure-test the system to distinguish internal from external leaks.
