This problem is driving me crazy, I have a 1991 Chevy Cavaliel with approx 117,000 miles 2.2L, automatic. I am having a problem getting the cooling fan to work. The fan will not come on at all, not even if you turn the A/C on. I have replaced the thermostat, temp sensor, Temperature Switch, and even tried a new relay if there is only one. The only way the fan comes on is if you hardwire the fan to the battery or if you unplug the Temperature Switch. I really would appreciate some help, thanks
Vince
SPONSORED LINKS
Sunday, October 14th, 2007 AT 7:23 PM
