1997 Chevy Cavalier Front Wheel Drive Automatic 87000 miles
My cooling fan only works when my A/C is on. The temperature gauge works fine, but the fan does not come on if the temperature gets on the high side (without the A/C on), which occurs if I am in "Stop and go" traffic. I know that there is a temperature sensor that mounts on the the engine. Is thiis the same sensor that feeds the temeprature gauge on the dashboard? If it is, then what else could be causing my cooling fan not to come on based on enginer temperature?
SPONSORED LINKS
Monday, July 21st, 2008 AT 2:37 PM
