1989 Chevrolet Cavalier Engine Swap
89 CAV RS
The 3.1 liter engine is blown. I also have a 1988 Pontiac Sunbird (2.0 Turbo). Can the engine be swapped to the Cavalier? I know the spindles need to be swapped, but what about the engine and tranny mounts?
Jun 11, 2007 at 1:57 PM
E40WATER12
  • 522 POSTS
Yes the engine can be swapped in, U will need the swap the ECU (computer) Wiriing harness, Also engine and tranny mounts, Also might have to do some Fab custom work, I would think it would be wise to get another V6 engine swap it iits place.
Good Luck.
Jun 11, 2007 at 9:19 PM
Suggested Repair
A matching V6 is the wiser replacement for the blown 3.1. A 2.0 turbo swap is possible but requires the donor ECU, wiring harness, and engine and transmission mounts, plus possible custom fabrication.
Conversation Summary
The owner of a 1989 Chevrolet Cavalier RS with a blown 3.1 asked whether a 2.0 turbo from a 1988 Pontiac Sunbird could be swapped in, including engine and transmission mounts. The expert said the swap is possible if the ECU, wiring harness, and mounts are also swapped and some custom fabrication may be needed, but recommended installing another V6 instead.
