2005 Chevy Cavalier Clutch
NIC.ORTEZ
  • 2005 CHEVROLET CAVALIER
  • 4 CYL
  • MANUAL
  • 100,000 MILES
My clutch pedal goes down to the floor and gets stuck, and I can't shift into any gear. I replaced the clutch and the slave cylinder last year. It happened out of nowhere, the clutch wasnt getting stuck or anything!
Sunday, October 3rd, 2010 AT 12:12 PM
MMPRINCE4000
  • 8,548 POSTS
Check the return spring, but it is possible the clutch is binding. Check hydraulic level in clutch MC, look for leaks at slave cylinder.
Check motor mounts, If OK you will have to remove clutch.
Monday, October 4th, 2010 AT 8:53 AM
NIC.ORTEZ
I checked the hydraulic fluid today and it seems perfect, and I didn't see any leaking anywhere. But then again its not in the most conveinent place to look as well as I should. I'm pretty sure I need a new spring for it, I'm going to look at it more closely when I get time off work. Thanks for your help, I appreciate it!
Monday, October 4th, 2010 AT 7:21 PM
MMPRINCE4000
  • 8,548 POSTS
Thanks for using 2carpros.
Tuesday, October 5th, 2010 AT 9:53 AM
