Clutch pedal fell to floor and will not return
CHRIS'S
  • 2002 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • MANUAL
  • 120,000 MILES
Clutch pedal fell to floor will not come back up unless use your hand. It has no pressure. Replaced master an slave cylinder and hydraulic line. What could it possibly be?
Monday, February 20th, 2017 AT 12:26 PM
  • 31,937 POSTS
Probably has air in the system still. How did you bleed the system?
Tuesday, February 21st, 2017 AT 2:19 AM
CHRIS'S
Gravity bled it.
Tuesday, February 21st, 2017 AT 2:51 AM
  • 31,937 POSTS
May need to pressure bleed. I feel that there is air still trapped in the system.
Tuesday, February 21st, 2017 AT 3:34 AM
CHRIS'S
I was thinking the same. I just wanted another option. Thank you
Tuesday, February 21st, 2017 AT 3:57 AM
  • 31,937 POSTS
Okay, let me know how it goes.
Tuesday, February 21st, 2017 AT 5:21 PM
CHRIS'S
Took master with tank an hydraulic line all hooked up a bled it out that way then put it back on the bled it out with one person at pedal an one at bleeder an got pedal an pressure back in pedal thank you so much
Wednesday, February 22nd, 2017 AT 12:40 PM
  • 31,937 POSTS
Good job, thanks for using 2carpros, see you again some time.
Thursday, February 23rd, 2017 AT 3:27 AM
