The front seal is a lot less expensive to change, because it is easier to get to.
Find out where the leak is coming from, if rear (or front) seal it will eventually have to be changed.
Bad oil leaks will not only cost you oil, but the oil leak MAY work its way to the exhaust system and the POSSIBILITY of fire is real.
Take the car to a trusted ASE certified mechanic and have them isolate the location of the leak.
It could also be an oil pan, oil pressure sender etc.
SPONSORED LINKS
helpful?Yes
Monday, May 11th, 2020 AT 12:28 PM
(Merged)
