Did you check the old starter to see if would kick out the drive gear and spin? Did you check out the flywheel teeth?
Usually, I can lay the starter motor on the ground, hook up jumper cables properly between starter motor and battery, It will kick out the drive gear and spin, laying there on the ground. Of course that is no load test.
Feb 19, 2017 at 7:14 AM
