2004 Chevy Cavalier Ignition Coil
100,000 MILES • 4 CYL • FWD • AUTOMATIC
BRYAN1976
Have already put in a new starter, starter cylinoid, battery, and had alternater test which shows now problems.. Still have problem where sometimes the car starts and sometimes it doesn not.. sounds like a VERY low battery, but battery is fine, and still charged.. when you jump the car across the post on the starter, it starts just fine... I'm hearing it could be the "ignition module".. where is this, and how do I test this?
Oct 22, 2010 at 5:58 AM
  • 75,988 POSTS
Hi bryan1976, Welcome to 2carpros and TY for the donation
If the ignition control module is defective the engine will not start-I strongly recommend you inspect and test the park and neutral switch and ignition switch-if you have to jump the starter for it to start-Let me know
Oct 22, 2010 at 6:30 AM
