2002 Chevy Cavalier TRAC OFF & CHECK ENGINE LIGHT ON
JAXDOUG
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • 180,000 MILES
My trac off light is on and when I turn to the left, and give it gas it feels like the tire is trying to catch traction. When it finally does, it jerks into gear and then is fine, but it's only when I turn left. I was told the check engine was a faulty oxygen sensor. The car seems to be driving fine. Any suggestions.
Wednesday, January 16th, 2008 AT 11:45 AM
MASTERTECHTIM
  • 4,750 POSTS
I would double check the transmission fluid level. Also if you have a loose wheel bearing on left side could affect the wheel speed sensor. Or you could have a bad speed sensor. I hope this helps. Feedback greatly appreciated.
Wednesday, January 16th, 2008 AT 11:48 AM
