engine overheating or the water pump is not up to snuff?
139,000 MILES • 4 CYL • FWD • AUTOMATIC
THINKER?
Hi guys, I am wondering, I just flushed out cooling system,replaced thermostat and installed a thermostat, purged the air as required. It seems that when the car reaches temp@ 193 thereabouts, the fan does come on as designed, but while the fan is running only cool air is pushed from the engine side of the rad.Since I have driven the car about 100 miles and the temp stayed at 190, I am thinking possibly the rad mat be restricted,or the water pump is not up to snuff. What do you think? I am not real sure! Thanks
Nov 24, 2009 at 10:04 AM
SQM
  • 6,383 POSTS
The engine operating temperature for your vehicle with the 2.2L engine is 190-200 F .
As you mentioned you vehicle stays around 190F, then it is within the typical range and the cooling system is operating as designed.
Here is a helpful article on engine overheating symptoms for your reference:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Jul 22, 2021 at 3:35 AM
