Friday, August 6th, 2010 AT 10:29 AM
Ignition stuck in ON position. Had to pull fuse to stop engine. Gear shifter locked in park. Radio, A/C control, clock won't work. I messed with some silver switch under the driver side. I thought it was to disable the security system, and then the clock or anything hasn't worked since. If you need further information or a picture please let me know.
