2001 Chevy Cavalier Oily Spark Plugs
GRACEPCC3
  • 2001 CHEVROLET CAVALIER
  • 4 CYL
  • 99,400 MILES
I'm taking care of my husband's car while he is in Iraq and I don't know much about cars, so when I take it in and the mechanics tell me something is wrong, not sure if they are just trying to rip me off or not. They changed the gasket because oil was leaking and then they said the spark plugs were oily and would need to be changed for it to run more efficiently, particularly with gas mileage.
I didn't want to say yes to it at that moment, so thought I would do some research and also ask if this is a necessity.
Would be grateful for any advice.
Thank You!
Sunday, June 8th, 2008 AT 4:00 PM
MASTERTECHTIM
  • 4,750 POSTS
Oil probably leaked from the valve cover gasket and is on the outside of the spark plugs. Changing plugs and wires if they are covered in oil would be a good idea but if its running fine then you dont need to do the job right away. It can run a long time with oil on outside but if it starts skipping then change plugs and wires. Hope this helps
Sunday, June 8th, 2008 AT 4:05 PM
GRACEPCC3
What do you mean by "skipping"?
Sunday, June 8th, 2008 AT 4:13 PM
MASTERTECHTIM
  • 4,750 POSTS
Misfiring or running on 3 cylinders. You will feel the engine jerking or skipping when you try to accelerate.
Monday, June 9th, 2008 AT 6:13 AM
