2001 Chevy Cavalier HEAD LIGHTS
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
ICEMAN271983
Why is it that after my wife hit a deer the driver side head light wont work but the high beam does if i dont turn the lights on they flicker. Then the service light comes on. I tried repacing bulb doesnt work. What do I do plz help
Nov 8, 2008 at 9:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
First you need to get the codes that the engine light is giving off. Check for any loose wires where the headlight assembly is. The wiring harness may have been busted after contact causing loose or faulty wires. Check fuses and relays as well.
Nov 8, 2008 at 11:09 AM
