I wouldn't use a 20 amp fuse on that circuit. The 10 amp hvac fuse, that circuit is ignition feed, goes hot when you turn on the key, no voltage with the key off. You can check fuse circuit with test lite, among others that is feed for the coil side of the blower relay, in power distribution center, shouldn't be any feed, with the key off. That feed does go through the hvac controls.
You can unplug the relay, with everything turned off, see how many terminals have voltage? You could also check for continuity between the terminals for the switch side of relay, if there is continuity between these terminals on the relay itself, the relay is faulty. I don't know if a new relay would stop the fuse from blowing?
As far as blowing the fuse, it might be a short to ground on that circuit.
SPONSORED LINKS
Tuesday, December 9th, 2008 AT 1:13 PM
