Need to pull the switch out of the dash and get a test light. Should have power (key on) at the orange and brown wires. If not recheck fuses (Rdefog, HVAC) if power turn switch on, Purple should have power, if not switch is probably bad. Black is the ground. There is a timer circuit in the switch that could have burned out
SPONSORED LINKS
Friday, September 19th, 2008 AT 8:17 AM
