2000 Chevy Cavalier no low beams or DRL headlights
TYRONE101
  • 2000 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 78,000 MILES
When car is put in gear DRL clicks a few times and service light comes on. High beams are all that work. I removed left headlight fuse and headlight remained on but dim. What's the problem?
Thursday, December 27th, 2007 AT 8:56 PM
2CARPRO JACK
  • 11,533 POSTS
Are the low beam bulbs good? Do you have a test light or meter to check some things out?
Saturday, December 29th, 2007 AT 7:22 AM
TYRONE101
Yes the bulbs are good. Yes I have a multimeter
Saturday, December 29th, 2007 AT 7:51 AM
2CARPRO JACK
  • 11,533 POSTS
Lights on- check for power at bark blue wire. Low beams come straight out of the headlight switch. Go to DRL relay on fuse panel lower left side of dash. 87a should be power, 87 ground, 30 goes to headlights, 85 is the trigger from the BCM to turn on DRL's There are also 2 headlight fuses to check in the same fuse panel
Sunday, December 30th, 2007 AT 8:31 AM
