2000 Chevy Cavalier Air conditioner Compressor
2000 CHEVROLET CAVALIER
87,000 MILES • 4 CYL • FWD • AUTOMATIC
REXKEEGAN
What is the correct way to change an AC compressor with kit?
Mar 9, 2009 at 8:41 PM
THETOOLMAN
  • 123 POSTS
Are you talking about changing the whole compressor and freon or are you talking about converting from R-12 to R134? Due to the current laws of the EPA you should have a certified tech. do this for you. The system is under high pressure. If you are familiar with the system then you know you need to have a vacuum pump and or recovery system to evacuate the old freon.
A vacuum should hold on the system for 24 hrs before pressurizing the system with the new freon.
Good Luck.
Mar 10, 2009 at 8:33 AM
