Heater problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
What is the location of the thermostat on my car and how hard is it to get to? Is it an easy fix? Thanks
Wednesday, December 10th, 2008 AT 1:47 AM
MMPRINCE4000
MECHANIC
Follow the upper hose to the engine, intake manifold or head, you should see a housing that contains the thermostat.
You have to partially drain the coolant, remove housing, replace thermostat and gasket.
