Since your last reply, I have determined that the fan is defective. I have been able to release the fan assembly, but unable to remove it due to the upper left frame portion being in a track on the radiator and very tight space to work with. Is there a special method to use in removing this part?
Also, there is no power to the high beam lights. I have determined this with the high beam switch on and the use of a 12volt meter. I have been told that there may be a broken wire in the wiring harness near the battery. Are you aware of this type problem with this type car, also the same for the pontiac sunfire, and were is the most likely spot to find it near the battery?
Sunday, November 2nd, 2008 AT 3:26 PM
