HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Engine Cooling
Cooling Fan
SPONSORED LINKS
1997 Chevy Cavalier cooling fan won't run
JHEAN2K
MEMBER
1997 CHEVROLET CAVALIER
Electrical problem
1997 Chevy Cavalier Engine Size unknown Front Wheel Drive Automatic 148000 miles
my cooling runs only when my aircon is on. When my air con is off the cooling won't run. What seems to be the problem
Saturday, December 1st, 2007 AT 12:35 PM
MECHANIC
Check the coolant temperature sensor
SPONSORED LINKS
Sunday, December 2nd, 2007 AT 3:36 AM
Please
login
or
register
to post a reply.
Related Cooling Fan Content
1997 Chevy Cavalier Cooling Fan
Engine Cooling Problem 1997 Chevy Cavalier 4 Cyl Front Wheel Drive Manual I Am Having Problems With The Tempature Gauge It Is On Hot...
Asked by
sunflower7
1997
CHEVROLET CAVALIER
GUIDE
Radiator Cooling Fans
The engine cooling fan is designed to move air through the radiator when the vehicle is at slower speeds or stopped. This air flow removes heat from the coolant created by...
1999 Chevy Cavalier Radiator Fan
My Radiator Fan Will Not Cut In When Coolant Starts To Over Heat.
Asked by
derrick andrews
1999
CHEVROLET CAVALIER
1998 Chevrolet Cavalier Radiator Fan Has Stopped...
1998 Chevrolet Cavalier Mileage: 165,000. My Radiator Fan Has Stopped Running Which Is Causing My Car To Run Hot. I Was Told By Somebody...
Asked by
2CP-Archives
1998
CHEVROLET CAVALIER
Car Is Turned Off And Electric Radiator Fan Is Still...
Car Is Turned Off And Electric Radiator Fan Is Still Running. It Killed Battery. Looking For Solution. Bad Contact Maybe?
Asked by
bpisani1102
2005
CHEVROLET CAVALIER
Water Pump/thermostat/radiator????
My Car Keeps Running Hot While It Is Idle, And Will Not Keep Fluid In The Radiator Reservoir. I Continue To Fill It, But It Will Not...
Asked by
jenellepere
1 IMAGE
1997
CHEVROLET CAVALIER
VIEW MORE
Online car repair manuals
