Driver door latch
BRANDONCOURTY
Interior problem 4 cyl Two Wheel Drive Automatic
Hi. I opened my door this morning and started the car. i went to close the door but it would not latch. It was -10 degrees celcius. i tried to close the door while i held the handle in the upper position then let go when i closed the door, but nothing happened.
Dec 8, 2008 at 6:55 AM
  • 55,673 POSTS
It sounds like the door latch itself is broken and needs replacement. You will need to take the door panel off before you can replace the latch.
Here is a guide that will give you an idea of what you are inf for.
https://www.2carpros.com/articles/door-panel-removal
Cheers, Ken
Jan 23, 2018 at 9:46 AM
