Door Latch
22,000 MILES
SHARONDA JOHNSON
Door will not close latch appears stuck.
Jun 25, 2017 at 1:42 AM
HMAC300
  • 48,601 POSTS
lube latch as much as you can then try from inside and outside opening with a large screwdriver turn latch while opening. if it does not work then pull door panel off and look for broken clips at latch.
Here is a guide that will help
https://www.2carpros.com/articles/car-door-hood-or-trunk-will-not-close
Jun 25, 2017 at 3:22 AM
SHARONDA JOHNSON
Thank you for your response. I fixed it.
Jun 25, 2017 at 4:30 AM
  • 55,676 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Hmac300 is one of our best!
Cheers, Ken
Jun 27, 2017 at 8:13 AM
