The problem is, I've got only side marker works and high beam, during day or night, no others lights at all works eather in the dash, nothing lights up.
Could you help me,
Thanks
Saturday, May 31st, 2008 AT 4:50 PM
CHOUZE1979
MEMBER
I would go out on a limb and say it is more than likely going to be your headlight switch, I had the same problem. My marker lights would come on and the only headlights I would have are my daytime running lamps. On occasion the head lights would come on but if you used your turn signal or hit a hard bump they would shut off back to the daytime running lamps. So I would give it a shot and replace the switch.
